Old Dec 26, 2011 | 10:20 PM
amx1397
Default Re: Stacked pulleys - 23psi with no codes. :)
For someone that posts as much as you, you don't seem to read much at all. You must have missed all my threads on running lean, solving it with a SL55 fuel pump, and how correcting the A/F netted me a 5mph increase in trap speed. I'm just a newb, so you probably don't read my threads.
I haven't data logged yet, as I'm letting it get broken in. A quick glimpse of the A/F at WOT showed a range from 11-13 A/f. I'll datalog once the car makes open loop adjustments based on closed loop trims.
sorry to ruffle your feathers, well not really.. i did read your post on the sl 55 then i had my friend read it to me so i was sure i didn't miss anything. also I did the sl55 pump 2 years ago, when i stacked the 178 and code 3 SC , my afr were 13,3 to 13.5,(thats to much) at 22.5 lbs of boost , as we know each car is different, i hope yours works out for you, stacked and all . you may not be a newbe but sometimes you really sound like one.,, either way keep us informed as WE can and do learn from others. Happy new year jim
