Old Dec 27, 2011 | 11:36 PM
  #57 (permalink)
grip grip's Avatar
grip grip
Default Re: Stacked pulleys - 23psi with no codes. :)
Originally Posted by amx1397
Hay grip,have you even talked to Rob yet you know he is in the for the cars not the money look at this ,, maybe you should give him a call. jim
http://www.needswings.com/ProductIma...uelsystems.jpg
note this part of the above:
from Needswings fuel system on Needswings site.
[FONT='Arial', 'sans-serif']We intentionally did not add larger injectors to the SRT6 due to wanting the car to run properly during not wide open throttle operation also. Larger injectors would be "broad swording" the issue and the car would be running extremely rich while normal driving. We have seen our fuel system supply more than enough fuel for 25psi thru the factory injectors at a factory injector duty cycle. [/FONT]
Thanks Jim, but I simply cannot justify spending that kind of money for the full setup. I just don't have it.
