Old Dec 28, 2011 | 12:03 AM
blackbelt_010892's Avatar
blackbelt_010892
Default Re: Freshly Wrapped A-pillars & New Headliner
Looks good. I am doing the same thing at the moment with CF fabric, the pillars are already done and everything is getting pulled apart very soon.
A suggestion: continue the color over the plastic parts continuing into the hatch so it does not have such an abrupt stop, and get SLK black sun visors to make it look OEM
Thanks for the tip with the SLK visors, I will be sure to look into that. As far as the cargo area, I have decided to keep that as for a few reasons; I have multiple RCA's and 2 gauge power and ground wire fed through the panels, and let me tell you they are an absolute pain to get everything to snap and slide back together. There is still a piece that the seat belt slides through that I cannot get to sit flush. I don't want to spend the money on wrapping all of panels when I can seem to manage to get them piece together correctly to begin with. After doing a search on new headliners I saw that member rfors777 was having similar problems.
I also have a more permanent Subwoofer/passive radiator and amp rack installation in the works. Once that is installed I may try and tie rest of the interior in together.
