Old Dec 28, 2011 | 10:59 PM
onehundred80
Angry Re: I need help big time with the car, please read on.
Originally Posted by Adrian_X
i don't think its the Relay Control Module at all, because the engine cranks and TRIES to start. If it was that, it wouldn't be trying to start at all.
So you replaced your starter relay sensor and it now starts no problem?
Also, my car is a 2004 coupe, red.
Oh! Red, that is the problem right there. Solved.
The Relay Control Module has more than one relay and it may turn over but not start.
Anyway, can you hear the fuel pump when you turn the ignition switch to 'ON' position only? If not it could be a fuel pump problem, no fuel = no start.
If you do not hear the fuel pump and then turn to the starter position and it does not start, you have probably found the problem.
Your symptoms have been in three posts, your car does run when it starts up just fine but you said that in the third post.
Please list all the symptoms, maybe there's more to come.
