Old Dec 28, 2011 | 11:53 PM
onehundred80
Default Re: I need help big time with the car, please read on.
Originally Posted by Mrmiata
About the only thing that comes to mind.. would be the filter itself. If your like me.. you have no real idea of anything done prior to your ownership. I would ask how many miles, but that's not the only factor sense one tank at Billy Bobs catfish bait and gas could clog a filter..
The fuel rail will hold the fuel pressure if all is right, it does not take too much fuel to be pumped to reach the operating pressure as gasoline is not air and is negligibly compressible. But there are check valves and pressure valves in the fuel pump and filter. If these are not working the fuel pressure leaks down and the injectors need the pressure to work.
I never wait for the pressure to build up, I just turn the key straight to the starter position and have no problem at all.
Now Valky listed problems he had which if I remember were similar and solved it with a new fuel pump and filter. But I shall check for his post and add it here when I find it.
Here it is.
https://www.crossfireforum.org/forum...-rudy-did.html
