Re: I need help big time with the car, please read on.
try your best to talk to the crossfire mechanic. go by there before your car is to be taken and ask to talk to the crossfire mechanic that will be doing the work on your car,, believe me if you can talk to him that is like five stars on your part. then when you take your car in tell the service rep you want that mechanic to work on your car,, i went to two different dealers the third one they sent the mechanic out to me , I would then get anything i wanted, yea i tipped him good. example I wanted a 4 wheel alignment,, service said not covered,, my mechanic wrote up wheel bearing bad and lower control arm bad alignment required,, no only did i get the alignment i got new control arms ( the bolts were the reason the control arms were replaced. try it you have nothing to lose. jim
oH the filter also has the regulator in it so it should be covered,,call it the ,fuel regulator so you need your fuel regulator and fuel pump replaced.
