Originally Posted by 32krazy!
right off the bat the oem are 480 cc injectors these are 550cc injectors. the TTM also have a dual spray pattern that replicates as close to a direct injection spray as possible. they also use the oem retaining clips whih other injectors dont use. this allows the injector to be held in place with the clips and not just the 4 bolts holding the rail in place
Is it 550cc flow at 3 bars PSI? The rest is a little confusing. The 1130780123 is an updated OEM injector. Don't they also have a dual spray pattern and the oem clips?
