Originally Posted by ImportLabSRT
Oh really?!?! As stated above, would you mind sharing the length from the tip of the stick the two marks should be?
Here is the chart you need to make an accurate level. The oil level is measured from the oil pan. I would make a mark about 60 mm and 65mm on the stick, then check it after you have driven it for a while to be sure it is up to operating temperature, 185°+. The level should be between the marks.
