Old Jan 2, 2012 | 11:51 AM
Yanksmell's Avatar
Yanksmell
Default Re: LED Tail/Stop Lights
Originally Posted by REDCROSS
This is the Number Two thing we talked about at the Nats...
I have always wished the tail lights were solid red...
It was the XFC that belongs to acripsy1 that has smoked out headlights and taillights by using a special vinyl like window tint that had the solution!
We were engineering the idea and there was the answer in front of us!!!
BUT I WANTED IT IN RED!!
SSSSSSssssssoooooo...EBAY here I come...
Rvinyl.com had exactly what I was seeking (as well as all kinds of other "STUFF").
I made a pattern (since the vinyl IS NOT laser cut) and went to work.
Since I have done window tint before I had a good idea of what to do...
BUT...since the taillight is a compound curve, a heat gun is required. GO SLOW!! Can't be too hot and can't be too cold!!
That fine touch process I did NOT have in the history file in my bald data bank.
I have a few bubbles and a wrinkle or two but IT LOOKS AS SICK AS CAN BE!!!
Check it out below!!!
1 - Without Tint
2 - With Tint
3 - Half Way Point
4 - Compare Tail Light
5 - Compare Stop Light
6 - All Done
As soon as I get a chance I'll take some posed shots so we can see how well the tail lights blend with the paint!!
-JD
I have looked at your mod over and over and can not figure which I like, with or without the tint. I like both but I think I figured out the big differance.
The tint allows the car to become more homogeneous taking on a more expensive look.
The stock lens has the clear section that causes the light and the trim to work as team (of sorts).
Final (my) understanding is the stock gives the car a twikle (so to speak) that works with the chrome (not the muted silver) trim while the tint gives the car an expensive look. I note that most high end cars do not put amber on the rear lights.
I like the red on red and with my yellow, red and yellow accent each other. i like both looks which is no help to me at all, crap.
