Old Jan 3, 2012 | 06:41 PM
MrMoPar's Avatar
MrMoPar
Default Re: Side View Mirror
If the base is tight, then the press on retainer for the spring that holds the tension on the mirror post has moved. If this is the case, will need to remove door panel to unplug the mirror connector to allow mirror to be removed so the tension clip can be pressed back down.
