Originally Posted by Mrmiata
Or one might take the more logical approach (and I know 32Krazy..not on your car)...
Variation Bolt AKA Wobble Bolt Bolt for PCD Variation
Hex17 M12 x 1.25 x 29.5
With this new item you can use one wheel with unified center bore for several applications. This bolt is fitted with a mobile conical washer which keeps the bolt axis perpendicular to the car flange while allowing radial displacement and a consequent PCD variation.
Set of 16 - $64.00 Set of 20 - $80.00
Hub Adapters and Spacers
really? would you install these on your car? when you get your turbo setup installed and your running say 150mph at the texas mile will you risk your life on this garbage? should make great video
