Thread: servicing
Old Jan 5, 2012 | 01:11 PM
onehundred80
Default Re: servicing
Originally Posted by crossfire121
The handbook is stamped up, the last service was at 73000 ,this was service No.4 Could someone tell me what work should of been done , i have just bought the car. Thankyou
https://www.crossfireforum.org/forum...ce_summary.pdf
Maintenance Service Schedule "A"
£ Change engine oil and oil filter.
£ Lubricate hood hinges, latch and secondary latch.
£ Reset FSS Display.
£ Check horn, Hazard warning flashers, turn signals, indicator lamps, headlamps and
exterior lighting.
£ Check windshield wipers and washer system.
£ Check fluid levels for hydraulic brakes system, power steering system, windshield
wiper system and engine cooling system (check corrosion inhibitor/antifreeze).
£ Inspect front and rear brake pads for lining thickness.
£ Inspect tires for damage, general condition and tire inflation pressures. Correct if
necessary.
£ Inspect body for paint damage (every 2 years).
£ Check chassis and supporting body parts for damage and corrosion (every 2 years).
£ Retighten steering locking bolts (50,000 miles or 4 years).
£ Check condition of driveshaft flex discs (50,000 miles or 4 years).
£ Replace fuel filter and air cleaner filter element (60,000 miles or 4 years).
£ Change the automatic transmission fluid and filter (80,000 miles). After this change it
is filled for life. Manual transmission comes filled for life from the factory.
£ Replace spark plugs. (1000,000 miles or 5 years).
£ Replace engine coolant using extended life coolant (1000,000 miles or 5 years).
Odometer Reading: ____________________ Date: ____________________
Maintenance Service Schedule "B"
£ Change engine oil and engine oil filter.
£ Rotate tires.
£ Replace dust filter ®
£ Check horn, Hazard warning flashers, turn signals, indicator lamps, exterior
lighting and headlamps (adjust headlight aim if necessary).
£ Check windshield wipers and washer system. Replace wiper blades if necessary.
£ Check seat belts for damage and proper function.
£ Check hydraulic brakes and parking brake function.
£ Check fluid levels for hydraulic brake system, power steering system, windshield
£ Inspect condition of front and rear brake discs.
£ Inspect tires for damage, general condition and inflation pressure. Correct if necessary.
£ Inspect major underbody and under hood components for leakage or damage.
(If leakage is found, determine cause and repair).
£ Inspect condition of front axel ball joints and rubber boots.
£ Inspect condition of steering components and rubber boots.
£ Inspect condition of accessory drive belt.
® Replace at 18,500 miles if not previously replaced.
