Old Jan 6, 2012 | 10:41 AM
onehundred80
Default Re: 74mm TB + MAF on Ebay
Since you are the TB knowledge king, I need to ask, is this truly plug and play? I know of them had to switch electronics and some were having issues. At this price, I am all over this combo, if it is not a huge PITA, I already have enough of those projects
Thanks Dave.
As long as the sensor from the OEM 68 mm MAF housing is switched over to the larger 74 mm MAF housing it is plug and play.
Mine never even coughed with the switch over. Some say they kept the larger MAF sensor in place and it adapted after spluttering for a while.
I did the maths and the old sensor in the new MAF is better when you compare the air volume, the square area of the larger MAF and hence the air flow required in the 6 and the V8. The V8 requires so much more air the 74 mm sensor would not see any where near the same conditions staying in the 74 mm housing.
To switch the sensor is a bit of a pain, as it was a five point tamper proof Torx screw. I used a tamper proof flat head bit and Beaner used a plain flat head bit. It chops up the socket a but but they are not to tight.
