Thread: Help :) ?
Old Jan 7, 2012 | 12:03 PM
32krazy!'s Avatar
32krazy!
Default Re: Help :)?
now look at the tensioner again. theres a nut on the center of the pulley and the shaft that the nut is installed on has a torx shape at the end of it. thats what you use to apply pressure to relaease the belt.using the nut will loosen when enough pressure is applied to try to release the belt. use the torx bit
