Re: Convertible
Hi Guys, I have another couple of problems that you may be able to help me with, bearing in mind I live in Scotland and the steering wheel is on the other side from you guys, the drivers side heated seat,ie the actual seat and not the backrest section stopped working ,it went really hot and then stopped working completely,although other seat is fine and also backrest heats up fine on drivers side, any ideas and likely cause and how to fix would be excellent,also on similar subject ,neither of my seats can be moved with doors closed and will only operate with door open, both seats move ok with either or both doors in open position,rather inconvenient at times. PS the tip on vinegar has worked a treat although I have to do this every week or so,it certainly helped alot,Thanks ,Teak
