Re: Can I use 35 mm offset on a 17 x 7 inch rim? (for snow tires)
JBsZ06, I don't think the slightly larger offset should make a difference since the rim is only 7" wide, and you will be using a narrower snow tire. The current rear wheel on your car is 9" wide, so that would put the inside of your tire alot closer to the inner fender than a 7" wide rim would. I hope this answers your question...Mike
