Old Jan 14, 2012 | 01:26 PM
amx1397
Default Re: Needswings duel intake on V8 crossfire
Originally Posted by MikeR
Jim, did you break or bend something or what???
I thought i did because the pass wheel was moving back and forth about an inch when the brake was applied. at 120 (at the track) i let off the gas and the car wanted to go sideways and when i hit the brakes to slow down the car wanted to go sideways the other way so i parked it ,,,drove 70 miles home jacked it up and wow ,,, I was going to take everything apart and make adj, links for all three links on both sides and or make hard teflon bushings for all the rear links and lower control arms, but then i found one of the bolts loose the nut was on by 1or 2 thds.,, replaced that,, inspected everything and i'm back on the road,, took some measurements and am going to make all new links,,maybe.. or maybe just the bushings. jim
P.S. mike your links are great and did not cause any of my problem,, your links are so good ,that's why i may want to make all the links on both sides. thanks for such a good product.
