Originally Posted by rmaier
The belt is stock and the engine has 8,736 miles so the same for the belt. It is not strreched out and the tensioner is about 5/8 through its travel. Not maxxed out. This was just a solution I came up with not something anyone else has to try......Just my way of devising a solution to belt slippage. The T42194 smooth pulley works perfect for this for me.
not knocking your setup at all. a suggestion is replace the oem idler you moved with a 90 mm napa pulley. go to 100 mm if you cant find the 90. the oem tiny pulley sucks eggs and i replaced 3 within a yr.
