Old Jan 16, 2012 | 10:48 AM
Daniel454's Avatar
Daniel454
Default Re: SRT6 convert blank switch to on/off
I converted my blank to control my fog lights.
Gave me the ability to run the fog lights with high beams as well as allows them to default on anytime the headlights are on so I do not have to remember to pull out on the headlight switch....
It can be done with one small latching relay and one standard automotive relay.
The latching relay is essentially the item that will turn the momentary pulse to a constant signal. Unfortunately I could only find these in low current circuit board style so you must then take that latched signal to a full size automative relay to handle the current needed. Plenty of room in the dash for this though...
Many options exist for that latching relay, I chose a FRT3-SL2 Relay:
http://www.led-switch.com/Relays.htm
http://www.khalus.com.ua/data/chips/chameleon-relay/pdf/frt/frt3.pdf
Now if Rudy puts something together it would be a LOT cleaner and simpler I am sure, but this will work JUST FINE if you have the time to make it happen.
Here is my original thread with more info of exactly what I did. https://www.crossfireforum.org/forum...rks-fixed.html
