Old Jan 18, 2012 | 03:06 PM
onehundred80
Default Re: SRT-6 Liftgate Leak On Spoiler Mounting Plate
Hope it doesn't stick to both surfaces when you remove the panel. Good luck with it!
I took of the panel today and found that I had a pretty good seal all around. A bit light in the top right corner but still touching.It was not stuck too tightly and popped off OK, the caulk all stayed on the car side.
I now have to find a good adhesive backed seal that is not to wide. 1/8" thick x 1/8" or maybe 3/16" max. wide should be OK. If its too wide it takes too much pressure to clamp it down.
