Re: Stacked pulleys - 23 psi with no codes. :)
I should know this but, what intercooler pump do you have? My additional heat exchanger experiment isn't working out but I have the stock weak-a@@ pump. The knock on higher boost has always been the extra heat, as you know. Do you have the thermal coated I/C? I WANT ONE! I'm taking notes in case you didn't notice.
Les
