Old Jan 21, 2012 | 10:04 AM
  #93 (permalink)
amx1397
Default Re: Stacked pulleys - 23 psi with no codes. :)
Originally Posted by velociabstract
I should know this but, what intercooler pump do you have? My additional heat exchanger experiment isn't working out but I have the stock weak-a@@ pump. The knock on higher boost has always been the extra heat, as you know. Do you have the thermal coated I/C? I WANT ONE! I'm taking notes in case you didn't notice.
Les
Les , I am running a 2 1/2 year old stock pump,, I am also going to put an open vent(open all the time ) on my heat exchanger system, Open all the time so there is "0" pressure. jim
