Old Jan 22, 2012 | 09:08 AM
32krazy!'s Avatar
32krazy!
Default Re: Photos of DIY Rear Spring R&R?
rear is ez peazy max. jack it up and remove the lower 3 bolts in the lower control arm lower and take the tension of the spring. remove it and when you reinstall the easiest is to start with the shock. that holds everything in place then the other 2 tighten and do the other side.
