Old Jan 22, 2012 | 01:58 PM
  #102 (permalink)
32krazy!'s Avatar
32krazy!
Default Re: Stacked pulleys - 23 psi with no codes. :)
[QUOTE=dinasrt]
Originally Posted by 32krazy!
adj fuel press regulator, larger fuel filter w/ built in regulator, /quote]
Didn't you mean filter W/O built in regulator.
not at all. i recently found a ls1 corvette filter that is almost identical to ours but flows at 90 psi. to much. so the hunt is on for a regulated filter that flows in the 70 psi range. that allows more fuel to flow without getting to wild on the changes.
it would be easier to just add a high flow filter and an adj. regulator but whats the fun in that! the hunt is were i like to be
