Old Jan 25, 2012 | 02:31 PM
  #110 (permalink)
grip grip's Avatar
grip grip
Default Re: Stacked pulleys - 23 psi with no codes. :)
Originally Posted by waldig
DAG ON IT its not the injectors, its the pressure differential, just raise the rail fuel pressure a few psi and solve the problem, I had the same pressure 23 and got the fuel rich just with an increase of rail pressure to about 65 psig.................................
If you dont have an adjustable fuel regulator, see Rob, I did the testing of this and even went to 80 psi, durn near washed out the spark........ Woody; wake up and smell the coffee......
PLEASE SEE THE LISTINGS HERE> WOODY
Message - CrossfireForum.org Gallery
Fuel system upgrade - CrossfireForum.org Gallery
Fuel rail - CrossfireForum.org Gallery
I agree with you, but I'm being asked to give them a shot both by TTM and EC, so I'm going to oblige. If they don't work, I'll remove them and go back to 20psi until I locate an inline fuel filter with reg that maintains around 5psi more pressure than stock or I'll get a high flow filter and adj reg from Rob.
