First stab at the lean issue with a retune helped, but didn't fix it. It's up to EC whether we try adding more fuel or installing the injectors. Jerry wants me to install the larger injectors, so it's likely happening this week.
Are the injectors running static (i.e., 100% duty cycle)? If not, it would be a lot easier to simply add more injector pulsewidth (or fuel pressure) than swap injectors.
Also, what is fuel pressure doing at WOT? If it's holding steady or dropping only only a touch, then more inj pw (if available) will help. If it's dropping a bit, then more fuel pressure won't help as the pump is not able to keep up with demand.
