Old Jan 26, 2012 | 09:40 PM
tighed1's Avatar
tighed1
Default Re: Throwing a P0410 Code
Originally Posted by 6000rpm
Welcome to the forum!
It sure could be the air pump, but a lot of folks on this forum had the P 0410 code and it turned out to be the Relay Control Module. It's common to have bad solder on the circuit board.
Try this link:
https://www.crossfireforum.org/forum...-no-start.html
Good luck!
Ditto on the WELCOME!
Check the relay in this post from the above link.
This will cause the PO410 fault.
Originally Posted by tighed1
PLEASE remember that you need magnification to see the bad joints.
Don't want someone to look with the naked eye and think all is well.
You don't need magnifcation to see the problem some are having with the Air Pump relay. Checkout these pics.
Should look like this:
It's relay #5 in this picture from onehundred80.
