Awesome pics Tighed1! Much appreciated.
Now u raise a good point on the RCM because I actually had that replaced by a new unit because my other one was done and I did start occurring these issues afterwards, so maybe it could be that.
I'm going to check the valves first because the way my exhaust starts to sound I doubt its the RCM causing it which makes sense that water is somehow possibly getting into the air pump causing it to possibly stall? None the less I have to get this issue fixed, so Im trying other alternatives before I have to take it to the stealership. Ill check the air pump fuse to see if possibly its blown which I havent done. Ill keep this thread updated for future reference.
BTW, thanks 6000 much appreciated amigo.
Originally Posted by tighed1
Ditto on the WELCOME!
Check the relay in this post from the above link.
This will cause the PO410 fault.
It's relay #5 in this picture from onehundred80.
