Re: need help w/alarm please
The air pump/security module in the trunk under the foam on the passenger side has caused problems when it has got wet due to a trunk leak. This pump is an integral part of the security system, as it arms the alarm system.
Pull up the trunk carpet and peer down the back of the foam and look for water in the well. Look for signs of water in the trunk while you are at it.
