Old Jan 27, 2012 | 04:34 PM
fastfred's Avatar
fastfred
Default Re: need help w/alarm please
THANKS GUYS YOU WHERE RIGHT ON THIS ONE.....well i did some searching on here and found a lot of posts on this water in the rear area ...so i took apart the whole trunk area and under the foam thing i found about 6'' of water so i opened up the drain hole and let the water out... the foam thats around the module is soaked so i took it out and its drying now i also took all the pins loose and found water in all of them but no rust and no black shorting looking wire at all... so i have it all a part now and drying am i missing anything at this point?..... I'm hoping after it all drys I'll put it back together and hoping it works????
