Old Jan 29, 2012 | 11:55 AM
  #292 (permalink)
32krazy!'s Avatar
32krazy!
Default Re: My New Custom Wheel with Paddle shift
well i had time yesterday to play with the paddles. after many obstacles and time away to rethink the issues i had i have say this is the coolest mod yet! love the way they feel operate and look. went to grip's house and had to wipe down the seat, he wqas drooling all over it! jhm2k wont stay away from my car either!! so finally someone might just walk past all these xfires around me at the car shows to look at my paddles!!
magredvet i have crappy eyesight and didnt need a magnifyer. just slip the wire thru the hole and solder it gently. chris has tinned the ends for you already and its a very tight fit. you pass it thru and bend the wire on the board and it stays put were you need it. the disassembly instructions are exact and fotos help tons. i had my laptop sitting next to the shifter and had zero issues. aslo chris suggestion about testing after its done ensures you did it right .
let me add theres a tiny spring in the top of the shifter that holds the door closed for the shifter disengage. mine popped out and i had no idea were it was supposed to go. chris figured it out from 2000 miles away over the fone on a sat!! he has the best kit ever built!!
10080 i bow to your vast knowledge. after ripping my wheel completely apart i had the bolts out from 2 different slk32 wheels and the t30 IS the proper size!
