Old Jan 29, 2012 | 01:57 PM
  #295 (permalink)
SparkieSRT6's Avatar
SparkieSRT6
SSB SRT6 405hp/401Tq
Default Re: My New Custom Wheel with Paddle shift
Originally Posted by 32krazy!
i taped the entire backside of the wheel and used a sharp pencil to outline the template chris supplies. with the template held by one thumb and finger on the wheel i gently scored the outline. then each time pluging deeper into the rubber. once the outline is cut i made cross cuts inside the outer score and then just started peeling it out with a small screwdriver. as the hole gets bigger its easier to see what needs to be removed. the corners were the hardest to cut as i was scared the knife would slip as i was applying pressure to cut and slice the wheel. slo and steady is the key. remember the inside part of the arm is all rubber and thats were the slot needs to be cut to allow the wiriharness to pass thru. the outside of the arm has the metal at the bottom so you slice to the bone there and work to the inside. i spent prolly 1 to 1 1/2 hr on each side fitting the paddle and trimming fitting and trimming. maybe 2 hrs marking the tape and looking at it remove and try again to get the best distance angle and fit. add a dozen calls to chris for support and i did it!!
Exactly the procedure I did as well. The exacto I used was one of the small "crafters pen style" knives. I made sure to stay on my cutting marks but ended up making it slightly larger on the outside steering wheel edge so that the paddle could be mounted slightly more outside to give me a bit more finger space. Best to just take your time.
