Re: speaking of 74mm TB's
I also had a problem with the "O" ring on the TB at first. You can also have alignment issues due to slp in the mounting screw holes. Reach in the throat of the TB and feel the bore lip to make sure it is smoothe all the way around where the TB and manifold meet. Don't over tighten either. Hope this helps. Drives you crazy when you know it should run better and it doesn't.
