Thread: Dyno Results
Old Jan 31, 2012 | 01:03 AM
rmaier's Avatar
rmaier
Default Re: Dyno Results
Hmmmm where do you getyour emissions testing done???? They always setup the car on the rollers and it has to be in drive as the test is run because I've watched and the rear wheels spin accordingly. I see the display for the vehicle from the waiting room and the rpms as the test is administered and it goes through idle to 3600rpm several times unless you fast pass and even then it goes through the cycle at least once.
