Re: Trailer Hitch
I have not weighed the complete unit off the car. I would say that the entire assembly incuding the removable bar, bolts and backing plates is less then 50lbs. Nearly half of the wieght is removed when the reciever hitch is unpinned and taken off. The two hitch assemblies are bolted to the car, like any other hitch and all that shows from the back when the reciever is removed are the two small hitch openings. There are photos in my gallery.
This hitch is a better fit for the Crossfire, it is lighter then the hitch made for my car and the angle and tilt of the connection points are in perfect alignment. The kit is complete and painted black.
My trailer is the 5' model, the opening in the 4' model will not support 4 race tires. I would recommend a Harbor Frieght trailer if your using it primarily for racing gear, it's much cheaper and the tire spread is wider making it easier to back.
Your welcome. I will be wiring my sons hitch and can give you a color code guide for hooking up your light connections if needed.
