Hope you never want to upgrade your brakes, those 17s would be a killer. And if you do not lower it, it will look silly with 17/18 combo, IMHO...
The bigger brake kit Im not worried about right now, I wont track enough to even need it. I figure Ill be good with drilled and slotted rotors with steel braided brake lines.
Suprisingly the front will be .5" taller with the back the exact same, just wider on both. I do eventually want to lower it, but that wont be for a while.
Attached are the sizes when said and done:
