Old Feb 3, 2012 | 06:17 AM
32krazy!'s Avatar
32krazy!
Default Re: TCU and Rev Limiter
Originally Posted by Russcross
Friends, could you answer on my question.
As everybody knows we have 5-gear automatic transmission but in manual mode we can use only 4 gears ... Is some special idea take place? Could we use 5 gears in M mode? I find this strange and little bit stupid.
Thanks!
why do you think you cant use od? i works fine in mine.
moparburst the bouncing is causing a high afr spike during the shift lag. 20+ . jerry is adding the v3 to mine for datalogging. it reduced the tcu rev limits to 6200 and inc the torque limiters to 1000 newtons as well as adding the amg speedshift. it should hold gear at top rpm during m mode and fix the bouncing of the limiter. ill know monday when it shows up
