Originally Posted by 32krazy!
why do you think you cant use od? i works fine in mine.
moparburst the bouncing is causing a high afr spike during the shift lag. 20+ . jerry is adding the v3 to mine for datalogging. it reduced the tcu rev limits to 6200 and inc the torque limiters to 1000 newtons as well as adding the amg speedshift. it should hold gear at top rpm during m mode and fix the bouncing of the limiter. ill know monday when it shows up
It`s great that TCU works well. My question was about numbers of gears in gearbox. Is it all right that we can use from 1st to 4th in manual mode, and where is the 5th one?
Sorry if it difficult to understand my english.
