Old Feb 3, 2012 | 09:18 AM
onehundred80
Default Re: I need help with minor issues
Originally Posted by AzZcLoWn-_-
I haven't had any problems with my 2005 Chrysler except for the interior lights. There is a switch that toggles weither or not they are on when the doors are open, which I have flipped off all the time so I don't kill my battery. When the switch is turned on, the lights are on even if the doors are closed. Any ideas or tips?
Also I saw that the cross fire on the inside of the doors are lit up blue, how hard would it be to change thenlm to green?
The interior lights are operated by the door switches as you know and the switches hit a piece of trim on the doors, if that trim is missing the lights will stay on. If the lights are on too long they will automatically go off.
1, Do your doors go off automatically after five minutes or so? 2, Is the trim piece in place?
The door sills can be replaced with an OEM accessory that is blue, there may be a thread which tells you how to change the color, but I am not too sure on this, I'll look. Here it is, from the Guru himself.
https://www.crossfireforum.org/forum...r-install.html
