Feb 3, 2012 | 02:55 PM
469
permalink
onehundred80
Apr 2006
25,432
651
Ontario
Re: What did you do to your Crossfire today?
I fixed my WW fluid level sensor yesterday, hopefully, took it out, cleaned and replaced it and today I see the tank is leaking, bummer. I guess the sensor or pump are leaking around the seals. It is an awkward job to remove the tank, guess I'll be an expert when it's fixed.
I finished claying the car while the puddle grew. The fluid is running down inside the rocker panel. It is not overfilled, so that's not it. I should have put some sealant around the ends of the sensor and pump just like LugNut did in his write up on this fix. I have to fix it or nearly a gallon of fluid will be on the garage floor.
I don't think the topsider will work as the hose will not go around the bend in the filler neck.
onehundred80
View Public Profile
Send a private message to onehundred80
Find all posts by onehundred80
