Re: Wheel Bearing replacement
Autozone has the bearings for around $10 / set ( normal tapered bearings )
The service manual says no special tools required.
( if the hub race is scored, then you will need a new hub also ......
front hubs running around $75 on car-part.com )
NOTE: The XF has a 'clamp' nut, not the normal castle nut with cotter key
