It all depends on how rough the starting surface is and how good you want it to look. For most parts intended to be finished and painted, a 320 grit SP will marr the surface terribly and require you to do much more work. I would start with at least a 600 and work to a 3K, but again, it depends on how good the original finish is....
the surface is real smooth but they whant you to use epoxy primer wich is heavy
