Re: Will these rims fit properly?
If you really want to go smaller I would recommend staying as close to factory as possible... 18x8 +35mm for the front and 18x9 +22mm for the back. 5-112mm bolt pattern and closer to 68mm bore. Im not sure if a 73mm bore is a big difference or not but I would look for something closer to the 68 which is stock.
