Old Feb 8, 2012 | 11:27 PM
onehundred80
Default Re: Feeling sick and dumb
Originally Posted by dskul1
The cables were new and grounded to the engine. I did find out that there were some problems w/the battery and needs to be replaced. Probably the cause of the heated cables. The real news for me was that the pump module underneath the styrofoam pieces in the back was full of water as was much of that area. We now believe that this module was causing my lights to stay(draining the battery) on and preventing the locks from working. It is my understanding from reading other posts here that the problem is with the gaskets/seals that the rear wing is attached to leak and the water runs down between the panels and body. There weren't any easy to see "tracks" of water running down anywhere. If anyone has any other ideas about where this water comes from please let me know. Anyway the plan is to dry the module out - see if it works and replace if it does not. If the water is coming from the wing area I will need to re-seal that area better than the factory seals. Could use advice here also to what was learned from others w/this problem. Also, I learned that when we took the panels off the back there was evidence of significant accident damage to the rear of the car on both sides sometime in the past. Unpainted spot welds. Fortunately there was no visable damage to the unibody "frame". That is a relief. This also proves that CarFax is a bit of rip-off. This is the second time in 5 years I have purchased a car w/a CarFax only to find out the car has been in a significant accident that was not reported. CFax will not be getting my $ anymore. It really doesn't help much and doesn't live up to their advertising claims. Thanks for the help.
Water comes in by the seals on the panel that the wing is mounted to on the SRT6, past the O-rings that are on the studs of the SRT6 wing, presumably past the panel that the NA wing is on, past the two boots that the wires that enter the hatch pass through and past the gasket around the fuel filler door. Take your pick.
If the car has had an accident then water could come in through any gaps that are a result of the accident.
