Old Feb 9, 2012 | 01:59 PM
JesseJamessrt6's Avatar
JesseJamessrt6
Default Re: Where to buy Spring Pads/Shims
Originally Posted by velociabstract
At the time I was using Michelin Pilot Sport Cups 235/40/18 on the stock rims. 4 mm taller than stock. I just refrained from turning sharply while backing up. In the rear I had 265/35/19's on the stock rim with no rubbing that I remember. 4 mm taller than stock.
I'm currently running 245/35/18's on a 9" rim and 30 offset on the front with the same amount of rubbing. I have 285/35/18's on 10" rims with a 25 mm offset and have some rubbing on the inner fender well .... that I ignore.
I sold my Eibachs and gave away my spring pads in april. Now I'm riding on K&W Variant II. My car sits at 5" from the ground to the rocker panel just behind the front wheel and 5 1/8" at the rocker panel in front of the rear wheel.
Les
How was your coil over install? Did you have to modify anything? Do they cause any problems with your 10" wheels?
