If the low beams are pointing toward the ground, but the high beams are where they should be, the low bulbs are installed incorrectly.
There is an alignment tab on the base of the H7 bulb which must be PERFECTLY inserted into its slot or...they point in the wrong direction!
Look in the Sticky section in this Forum.
