Old Feb 13, 2012 | 11:59 AM
JHM2K's Avatar
JHM2K
Default Re: Passenger Airbag on an 06 Crossfire Coupe
JHM2K, isn't that switch keyed to the key for the vehicle? Or is there a regular switch body behind the key assembly they could throw when they need to. Just want to be sure before anything is sent that they can use it and not have it sit on a shelf somewhere.
Damn you're right, it is most-likely coded to the key itself.
Not electronically, as there's no transponder in the airbag switch... However, the actual "physical cut" of the key may be VIN specific.
Can someone with multiple Crossfires confirm?
If you can use one key to disarm both Crossfires, I will send her the panel tomorrow. If it's key-specific, we may be out of luck.
