Originally Posted by amx1397
did you change lug bolts? You might want to check, put the spacer on the wheel, and make sure that you have minimum of 5/8 of an inch of threads sticking through the backside, so that it will hold your tire on the car. I'm not telling you what to do, I just don't want anything to happen to the car, or yourself. It does look great, next time you buy tires you can buy a wider tire, Jim
yes i did..replaced the regular ones with longer ones..garanteed i have plenty of thread to securely reinstal tires back on
