Old Feb 17, 2012 | 01:05 PM
latemodel21's Avatar
latemodel21
Default Re: Lean spike - Stacked with Larger Injectors
Originally Posted by BLKFIN
Sad part was he had every mod you could buy and even some that he invented and the car could not get into the 11’s. I agree about the 25lbs of boost, but that is what he was seeing with just the 185 back then. He ended up trying a 181 and then came over to the “dark side” and bought a code 3. (This is when there was a huge debate about boost and pulleys)
My car…at the time, with a Code 3 Pulley, Needswings single intake, Eurocharged canned tune and 100+ lbs of subs and amps in the hatch on 20 x 10 rims could run just as fast as he could at 12.1’s – 12.2’s all day.
Sometimes... at least with these cars….less is more.
I have always suspected that given the overdrive of the waterpump (41%?) and accessories (17%) that comes with the 181 pulley, that a code 3 (65 mm or so) should make about the same NET power
Chris
