Well I've got it - few minor issues with boot latch sticking - now aware how to sort spring a bit weak so needs help on lever, headlamps misted up but some running with lights on should fix that (hopefully) biggest issue is other drivers. Car seems to perform OK - just put first lot of fuel in be interesting to see how long that lasts - traction control works fine too (too much boot too early & wet road)
. Seems the grunt is there so may use for work for a few days just to familiarise you understand (knew the business insurance was a good idea) roll on good weather even if it is a coupe
